I modified the code so it compiles now but I still get a quotient and a remain and not the whole result. Besides, if my input is std_logic_vector why convert it to ufixed and then back to std_logic_vector?
Library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.fixed_float_types.all;
use ieee.fixed_pkg.all;
entity PreNICOMFunction_fixed is
port (
clock : in std_logic;
reset : in std_logic;
I : in std_logic_vector (31 downto 0);
Q : in std_logic_vector (31 downto 0);
V0 : in std_logic_vector (31 downto 0) --;
-- temp_res : out ufixed (31 downto -32)
end PreNICOMFunction_fixed;
architecture rtl of PreNICOMFunction_fixed is
component lpm_divider1 IS --32 clocks latency
PORT (
aclr : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
denom : IN STD_LOGIC_VECTOR (63 DOWNTO 0);
numer : IN STD_LOGIC_VECTOR (63 DOWNTO 0);
quotient : OUT STD_LOGIC_VECTOR (63 DOWNTO 0);
remain : OUT STD_LOGIC_VECTOR (63 DOWNTO 0)
END component lpm_divider1;
type fsm_type1 is (s0, s1, s2, s3, s4);
signal fsm1 : fsm_type1 := s0;
signal QdivI : std_logic_vector (63 downto 0) := (others => '0');
signal QdivI_remain : std_logic_vector (63 downto 0) := (others => '0');
signal I_ff : std_logic_vector (31 downto 0) := (others => '0');
signal Q_ff : std_logic_vector (31 downto 0) := (others => '0');
signal I_fp : ufixed (31 downto -32) := (others => '0');
signal Q_fp : ufixed (31 downto -32) := (others => '0');
signal div_res : ufixed (31 downto -32) := (others => '0');
signal cntr1 : ufixed (4 downto 0) := (others => '0');
constant div_latency : ufixed (4 downto 0) := "11111";
begin
divider : component lpm_divider1
port map (
aclr => '0',
clock => clock,
denom => to_slv(I_fp),
numer => to_slv(Q_fp),
quotient => QdivI,
remain => QdivI_remain
main : process (clock)
begin
if (rising_edge(clock)) then
I_ff <= I;
Q_ff <= Q;
case fsm1 is
when s0 => if ((I_ff /= I) or (Q_ff /= Q)) then --New data availabe
I_fp <= to_ufixed(unsigned(I),31,-32);
Q_fp <= to_ufixed(unsigned(Q),31,-32);
fsm1 <= s1;
end if;
when s1 => if (cntr1 < div_latency) then --Wait for the division operation to complete (Q/I)
cntr1 <= resize(cntr1 + 1, cntr1'high, cntr1'low);
else
cntr1 <= (others => '0');
fsm1 <= s0;
end if;
when others => fsm1 <= s0;
end case;
end if;
end process main;
end rtl;
