10 years agoMapping inout to inout
Is is possible to map inout ports to other inout ports without resolving direction? The use case is for mapping local ports in a hierarchical design for abstraction naming only. I have an eval ...
10 years agoYou should avoid doing this. The inout is only for IO and a direction should always be given. You could create a short circuit when you drive one high and another low.
[edit]sorry missed the part about the separate board, you do need to use a bidirectional driver if you want the io to function both as in and out in the same design[/edit]
