RTutu
7 years agoMap multipliers to DSP blocks using Quartus 18.0
Hi, I want to map multipliers to the Arria 10 DSP blocks using Quartus 18.0 Pro. I'm using the following code from the template: module teste #(parameter WIDTH=18) ( input clk, input sig...
CheepinC_altera
7 years agoHi,
Sorry for the delay. Just would like to check with you if you have had a chance to try using the DSP Native IPs to implement your design to see if similar observation occurs? To avoid gating your progress, it is recommended for you to continue using the Q17.1 which is working while debugging on this. Sorry for the inconvenience.
Chee Pin
