AAnch
8 years agomalloc selects Flash address for DMA transfers in memtest.c instead of SRAM
Hi, In the current design there is NIOSII, DMA, Flash & SRAM implemented targeted for Max 10 FPGA. Trying to perform the DMA transfer as per the reference memtest.c I see the below code in questi...
Ahmed_H_Intel1
7 years agoYou Can add a variable address by mapping it based on the data size. But make sure you don't overlap the data.
Did you try the design provided with the modifications you are asking about?
