AAnch
8 years agomalloc selects Flash address for DMA transfers in memtest.c instead of SRAM
Hi, In the current design there is NIOSII, DMA, Flash & SRAM implemented targeted for Max 10 FPGA. Trying to perform the DMA transfer as per the reference memtest.c I see the below code in questi...
Ahmed_H_Intel1
7 years agoHello,
I've created a sample design (working on DE0_NANO_SoC) for the DMA including the following components(NIOS II processor, Two memories, DMA, Sys_ID and Jtag_UART)
The code show you how to set the channels, the data pointers start the transaction and to check the data receive success.
Attached is the full design files.
I hope this helps you and gets your satisfaction.
Regards.
