15 years agoHello everyone,
I think I worked out myself that I can't really use the nios2-bsp-create-settings and nios2-bsp-generate-files commands to generate the makefile as my version (nios II 7.2) is too old to use bsp files... So now, is there a way I can generate these makefiles without using these commands ? I believe nios IDE generates the makefiles itself before to build, and I guess it does that using commands, but which ones ? Thank you very much for your help ! Mat
