15 years ago
Macros with arguments in Verilog/SystemVerilog
Hi all,
I want to used parameterized Verilog macros in my code.
It looks somewhat as shown below:
`define ACTIVE_EDGE posedge
parameter ISO_SENSE=1;
        always @(`ACTIVE_EDGE isolation_ctrl)
           if(isolation_ctrl==ISO_SENSE)
              power_iso_flag=0;
I used "tick define" macro and parameter as I need my code to be somewhat generic.
Now, I want to extend the same for the following case:
(1) isolation_ctrl can be a vector with width N and it will have corresponding ISO_SENSE values. That is,
logic [NO-1:0] isolation_ctrl;
bit [NO-1:0] ISO_SENCE;
(2) If ISO_SENCE is 1, the macro `active_edge should take value posedge. whereas, it should take negedge for iso_sence=0.
I tried to do so using generate and macro with argument as follows:
`define str1 posedge
`define str2 negedge
`define ACTIVE_ISO_EDGE(a) ( a ? `str1 : `str2 )
module abc ( ...);
bit  sences='{1, 0, 0, 1};
generate
genvar j;
   for(i=0; i<NO_OF_DOMAINS; i++)
   begin
        always @( `ACTIVE_ISO_EDGE( sences) isolation_ctrl )
                power_iso_flag=0;
    end
endgenerate
endmodule
However, it gives the following error:
error-[se] syntax error
following verilog source has syntax error :
"env/assertions.sv", 309 (expanding macro): token is 'posedge'
always @(`active_iso_edge(ds[j]) isolation_ctrl_for_all_domains[j])
__________________________________^
Can anyone please help me solve this? I am not getting the exact way in which I can employ macros to make everything generic along with generate.
Hoping for some useful comments. :)
Gaurang
1 Reply
    It appears you have too many "`" in the expression. In your first example, ACTIVE_EDGE expands to posedge, but in the second example ACTIVE_ISO_EDGE( sences[i]) expands to `posedge, so the result will be ``posedge.
