14 years agoHi,
QSYS does create an SDC file which I also included in my TQ analysis. However, there are no clocks defined in this SDC file. Maybe that is the problem. It seems that I solved th issue by applying my own clock definition to this signal. It#s just a little unconfotable that I have to care about QSYS timing constraints, as I don't really know what the mentioned signal is doing. Thanks for you hints regarding the correct usage of report_timing! Maik
