As previous posts said, it is OK to have only the "p" leg of a differential pin pair in the source file and let the Fitter automatically create the pin for the "n" leg and place it in the correct location. However, you have the option of including both the "p" and "n" legs in your source file for Stratix III and Cyclone III. Here is the Help page for the primitive that lets you do this with input pins:
--- Quote Start ---
ALT_INBUF_DIFF Primitive
The ALT_INBUF_DIFF primitive allows you to name and connect positive and negative pins when a differential I/O standard is applied to an input pin. This primitive allows you to do the following:
Make a location assignment
Make an I/O standard assignment
Enable bus-hold circuitry
Enable a weak pull-up resistor
Make an on-chip termination (OCT) assignment to an input pin from a lower-level entity
This primitive is available for Cyclone III and Stratix III devices only.
Verilog HDL Example Instantiation:
module test_inbuf_diff (in, in_n, out);
input in,in_n;
output out;
ALT_INBUF_DIF inst1(.i(in), .ibar(in_n), .o(out));
defparam inst1.io_standard = "LVDS";
defparam inst1.location = "IOBANK_1";
defparam inst1.weak_pull_up_resistor = "off";
defparam inst1.enable_bus_hold = "off";
endmodule
--- Quote End ---
