11 years agoLPM_MULT, LPM_ADD_SUB Not working correctly with Modelsim v10.1.d
I am using the LPM_MULT and LPM_ADD_SUB for computing the magnitude of the FFT output. I am using scripts. Modelsim compilies everything. The LPM library is listed. However, the "result" output for two LPM_MULTs and one LPM_ADD_SUB are red and stay red.
Any idea of what's wrong? If I use Quartus (v13.0p1) and invoke Modelsim from Quartus (v13.0sp1) the LPM's work OK. The script works alright. Typical warnings. No errors. Compiles everything and invokes Modelsim v10.1.d It compiles both LPM's with no errors. Swimteam2 Replies
This generally happens when one of your input signals - on which 'result' depends - is not defined. Check the stimulus you're driving in.
Cheers, Alex - Altera_Forum
Thanks. I'll check the signals today.
