11 years agoLPM_MULT, LPM_ADD_SUB Not working correctly with Modelsim v10.1.d
I am using the LPM_MULT and LPM_ADD_SUB for computing the magnitude of the FFT output. I am using scripts. Modelsim compilies everything. The LPM library is listed. However, the "result" output for t...
11 years agoThis generally happens when one of your input signals - on which 'result' depends - is not defined. Check the stimulus you're driving in.
Cheers, Alex
