--- Quote Start --- How do I get the MegaFunction Wizard to generate me an lpm_decode symbol for BDF use that uses eq[] instead of the individual outputs? Thanks. --- Quote End --- Hi, as far as I know it is not possible. You have to do it by your own. Kind regards GPK - Altera_Forum
If you do not use the wizard and just place the symbol you will get an eq[] output.
Then right click the symbol, select properties, then change ports, parameters etc. Regards, rfournier
