13 years ago --- Quote Start --- Yeah... I think you are right, and I should explain a little bit more about the idea of the code. The input is a sine wave. The design will be implemented on a Altera Cyclone FPGA, installed on a USRP. The input clock has a frequency of 64Mhz. The input signal is compared to a counter(whose frequency I can change... knowing the frequency of the clock). At every time that input goes from positive value to negative(we use the 2's complement properties here... and exactly the fact that if the signal is negative the first bit is 1 and if positive the first bit is 0) the control wave is restored to 0 and the comparison between the input signal and the control one is done one more time. Hope this helps, Sorry for not doing it from the start. --- Quote End --- OK, so your sine input is running at system clock of 64MHz and for sine threshold of 500Hz you need to count up to 64000 (on 64MHz clock) for half cycle to see if sign bit changes(zero crossing) then pass it if so or more than 64000 clocks else mute it. Naturally you need to count 1/2 cycle and decide and may be you don't need to store that first half i.e. is it one check only to decide or you keep tracking your input in which case you need to store each half before deciding. My simplest algorithm would be: run counter 0 ~ 64000-1, checking sign bit regularly. if sign bit didn't change right to end pass input else mute. Thus you need first to determine the algorithm before writing code. We are also ignoring phase of sine input.
