13 years ago --- Quote Start --- Here is my new code: module filter(in,out,clk); input signed [11:0] in; output signed [13:0] out; input clk; wire [13:0]out; reg [17:0]counter; reg q; reg [11:0]t; assign out=(~in & t) <<< 2; always @(posedge clk) begin if(counter[17]==0) counter=counter+1; if((q==0) & (in[11]==1)) begin q=in[11]; t={counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17],counter[17]}; counter=18'b000000000000000000; end if((q==1) & (in[11]==0)) q=in[11]; end endmodule The output is still 0.... what do I do wrong? --- Quote End --- in my opinion you should assign the counter to : counter <= counter + 1 , the register counter is a D ff and it is under , in this case you are specified the edge-sensitive behavior of the circuit (posedge clk) so you have to put the none-Blocking (<= )assignments for your registers .
