13 years agoThe new code is working great for lower bites...(if you set the controlling bite of the counter 12 for example) but it seems not to work that great for 15,16,17... the output is just 0. Can someone explain why??? Moreover the output is still zero for frequencies as 1khz even if the counter is set on the 12th bite, but it works perfectly in the range higher than that.
