13 years agoYou could use signaltap to check what your system is doing.
While I'm not a Verilog specialist, I see that you use one bit of your 'in' vector as a clock, and this isn't a good idea. You could have metastability issues between your two always blocks, and your second block is sensitive to glitches. Your design would be a lot safer if you could include both parts inside the always @(posedge clk) block, and for example detect a falling edge on in[11] by comparing the signal to it's previous value.
