9 years agoLong FIR Filter
Hallo I am using MATLAB and Simulink to create my model and the using the HDL coder to generate HDL code for Altera FPGA. We have a custom hardware made from ep4ce22f17c6n with I2S interface an...
9 years ago --- Quote Start --- Hi the Fs would be 44.1 kHz for now. if possible we would like to go upto 96 kHz but then the filter coefficients are also getting double almost --- Quote End --- if you run a clock @ 100MHz then you have a ratio of 100MHz/44.1KHz ~= 2000 and you can then use MAC i.e. multiply accumulate sharing same mult for 2000 computations. so you will need 5 mults or so
