9 years agoLogic utilization of hello-world vector add
Hello. I recently compiled the vector add hello world example which comes with the Terasic DE1 BSP (Cyclone V). The report file, which was generated during the compilation of the kernel says that alr...
9 years agoWith SIMD of 4, you will get one copy of the kernel (not 4) but with up to 4 threads being issued in the same clock. To have 4 kernel copies and 256 work-items running in each copy, you should replicate your kernel pipeline by using __attribute__((num_compute_units(4))). Needless to say, SIMD is faster and more area-efficient than kernel pipeline replication, and the latter should be avoided unless you cannot use SIMD or you have already used the maximum-allowed SIMD value but still have area left on the FPGA. The "Intel® FPGA SDK for OpenCL Best Practices Guide, Section 1.7.3" discusses this subject.
For single work-item, if you don't use functions like get_local_id(), get_global_id() and get_group_id(), i.e. your kernel is work-group and work-item-invariant, the compiler will automatically compile it as single work-item; anything else will be an NDRange kernel You can also save a small amount of area by adding max_global_work_dim(0) to single work-item kernels to remove the scheduler. In NDRange kernels, threads or work-items are scheduled onto the kernel pipeline by the runtime scheduler in a way that keeps the pipeline as busy as possible; this could also involve out-of-order execution. Obviously, no dependencies should exist between threads in this case and data sharing between threads can only be done by using local memory and barriers. In single work-item, however, there is no scheduler involved anymore and loop iterations are issued onto the kernel pipeline by an Initiation Interval that depends on dependencies between the loop iterations. I Strongly recommend fully reading both the "Intel® FPGA SDK for OpenCL Programming Guide" and "Intel® FPGA SDK for OpenCL Best Practices Guide"; most common questions are answered in those documents.
