9 years agoLogic utilization of hello-world vector add
Hello. I recently compiled the vector add hello world example which comes with the Terasic DE1 BSP (Cyclone V). The report file, which was generated during the compilation of the kernel says that alr...
9 years agoTo put it simply (and maybe inaccurately to some extent), there is no thread-level parallelism on the FPGA unless you use SIMD. In other words, as you said, there will be only one adder on the FPGA, with work-items "looping" over that adder. Of course the adder is pipelined and hence, multiple work-items (threads) can be populating different stages of the adder at the same time, and speed-up will be achieved using pipelining instead of thread-level parallelism. With SIMD (applied to the kernel), however, there will be multiple adders and multiple work-items actually running in parallel. I recommend reading the first section of the "Intel® FPGA SDK for OpenCL Best Practices Guide" for more info on this specific subject.
