9 years agoLogic utilization of hello-world vector add
Hello. I recently compiled the vector add hello world example which comes with the Terasic DE1 BSP (Cyclone V). The report file, which was generated during the compilation of the kernel says that alr...
9 years agoCyclone V is a very small FPGA, you shouldn't expect to be able to fit a large design on it, even with HDL.
In the particular case of OpenCL, the BSP which holds the necessary IP Cores and logic for host/device communication and the OpenCL runtime uses quite a bit of area on its own, but this amount is fixed regardless of your kernel. In your case, the BSP is probably using 10% of that 15% logic and is actually bigger than the vector add kernel itself. The input size in host code does not affect area utilization; the only thing that affects area utilization on the FPGA is the kernel code and the BSP.
