--- Quote Start ---
I am using Stratix-III for my implementation. Is there any way that I force Quartus to only utilize the internal routing resources of a logic lock region for the contents of that LL region? For example I have circuit "A" and I want to explore the minimum LL region size that is required to *place* and *route* circuit "A". Is it possible and if yes how?
Thanks in advance.
--- Quote End ---
as far a s I know you could only prevent the placement of non-logiclock member inside the LL region. You can set that in the LogicLock Region Properties setting in the general
tab under "Reserved".
