12 years agoHas ANYTHING changed in the source (even just a version number)?
have you changed any project settings, pin assignments or device? Are you compiling on the different OS (Windows and Linux give different results for the same version)? I suspect something has changed, as the exact same source code with the exact same tool version with exact same settings will always create the same pof and sof files.
