10 years ago
logging error in vhdl
I got this error several times:
my code gets successfully compiled but the error is
"Logging is not supported for this item"
why this error is displayed, can anyone tell !!!!!!
    --- Quote Start ---
    Why in the world would you do that? Removing the file presumably removes some input stimulus from the testbench. The problem is that files cannot be logged to a Modelsim log file, not that it is not valid VHDL.
    Kevin
    --- Quote End ---
    As Tricky said this applies only for synthesis, for testbench it is ok, as long as you don't tell Modelsim to log the possible changes made.
    --- Quote Start ---
    any possible solutions please
    --- Quote End ---
    Post# 10 has the solution, read it and implement it. If you need more detail, you need to post more detail about what exactly you did that caused the error...as was described in post# 10 as well.
    Kevin
