10 years agologging error in vhdl
I got this error several times: my code gets successfully compiled but the error is "Logging is not supported for this item" why this error is displayed, can anyone tell !!!!!!
10 years ago --- Quote Start --- Why in the world would you do that? Removing the file presumably removes some input stimulus from the testbench. The problem is that files cannot be logged to a Modelsim log file, not that it is not valid VHDL. Kevin --- Quote End --- As Tricky said this applies only for synthesis, for testbench it is ok, as long as you don't tell Modelsim to log the possible changes made.
