12 years agoLocal memory in one work group
Say we define two __local memory A[1024] and B[1024] in the kernel function and the data-flow is DDR--> A --> B -->DDR, my question is that do they combine their read/write ports to generate common local memory system or preserve the individual read/write ports? I am sure that the common local memory system will greatly degrade the performance, even worse when many __local variables are defined.
According to the kernel log: " .. kernel number of local memory banks : 1 1 1 1 1 1 1 ", Does it mean 7 banks exist in my design? The memory utilization is much more than the __local memory defined in the OpenCL code, do the delay operations (with wider datapath, e.g. 32) require a lot of Block RAMs when the OpenCL code has relatively complex logic? BTY, I have roughly read the *.v generated by the AOC, and a lot of FIFO (with *.IMPL = "ram") are generated for delay operations. Does it mean we should avoid complex logic by generating multiple kernels?
