9 years agoLoading IP-blocks from IP folder doesn't work
Hi, I have a 4 software IP-blocks that I want to be installed under /drivers i the Nios II Software Build Tools for Eclipse.
From my instructor I got an IP-folder containing 3 Ip-blocks: BeMicro_Max_SDRAM folder, BeMicro_VGA_IP folder, and TIMER_HW_IP folder and their .h-files are put by the tool after project set up into /drivers. But my own IP-block VGA_UTIL_IP is not installed by the tool. Two things happens: i. It refuses to create the project completely, giving me the error message SEVERE: File not found "C:\Users\root\Documents\Ceng_100\Konstruktionsdokument\ip\VGA_UTIL_IP\HAL\inc\altera_avalon_timer_regs.h". SEVERE: File not found "C:\Users\root\Documents\Ceng_100\Konstruktionsdokument\ip\VGA_UTIL_IP\HAL\inc\altera_avalon_timer_regs.h". SEVERE: nios2-bsp-create-settings failed. Here is what bothers me: VGA_UTIL_IP does not use altera_avalon_timer_regs.h, only TIMER_HW_IP uses it. ii. If I add altera_avalon_timer_regs.h to HAL/inc,just to get rid of the error message, the project is generated but the tool does not put my vga_util.h in /drivers/inc nor the vga_util.c in /drivers/src The name of my folder is VGA_UTIL_IP, and the tcl script is named VGA_UTIL_IP_sw.tcl and looks like this: create_driver VGA_UTIL_IP set_sw_property hw_class_name VGA_UTIL_IP set_sw_property version 1 set_sw_property min_compatible_hw_version 1.0 set_sw_property bsp_subdirectory drivers add_sw_property include_source HAL/inc/vga_util.h add_sw_property c_source HAL/src/vga_util.c add_sw_property supported_bsp_type HAL Why does this not work?:confused::confused::confused: I am doing an include of an .h-file found from my instructors ip, in my ip# include <BeMicro_VGA_IP_Driver.h> Could it be that when the tool is interpretating my tcl-script it searches for that .h-file above, doesn't find it, and points the error message in wrong direction, so to speak? Greateful for some help /laskar01No RepliesBe the first to reply
