12 years agoThanks for the answer! That's what I needed.
But now, I'm experiencing another problem! I can't program flash anymore and can't figure out why ! I used to be able to program flash using the PFL megafunction or using flash programmer provided in the kit. This programmer uses Nios-flash-programmer. But now, I'm facing 2 problems : - With the PFL: I'm getting the error "can't recognize silicon id for device 1". I checked the IOs which are supposed to be bidir ... Everything seems ok and I'm using the same pfl.sof, so it should work - With the nios-flash-programmer : I'm obtaining the error : no cfi table found at address 0x08000000 when i'm trying to load a sof in the flash or when i'm trying to erase the flash. I'm kink of stuck with this flash ! Would someone would have hints of what I should check !? Thanks !
