13 years ago --- Quote Start --- The Linux and Windows tools don't produce the same bitfile (either sof or jic) - is this to be expected? The tools I'm using are: XP SP3, 32-bit: 12.1/SP1 build 243 Linux x86_64: 12.1/SP1 build 243, 32-bit There are lots of differences in the output - it's not just a date, for example. --- Quote End --- From memory some of the tools include the tool version in the sof/pof so differing output files isn't surprising. (I think if you should get an identical file out of each tool when it's run if all inputs are the same). Nial.
