17 years agoHi dalon,
I did USB-Blaster installation in CentOS5.2 using the method you described. It worked well. Thanx. @ErikZane and Vista: I had same issues as yours after I copied all the files given by dalon. I did "sudo killall jtagd" and then restarted udev. That solved the problem. Sincerely, Kumar Vijay Mishra.
