15 years ago
Linux Quartus II 10.0 sp1 standalone license issues
Hi!
I'm running the full licensed (standalone) version of Quartus 10.0 sp1 on SuSE 11.3. When I launch Quartus, the license setup appears asking for my license file or to continue 30 day trial. I have the correct path to my valid license file, but under "Local system info," the "Network Interface Card (NIC) ID:" reports "Not found."
My ethernet device (eth1) is up and running. I have no connectivity problems. I've tried reinstalling Quartus + sp1 while connected to the internet with no luck.
How does Quartus look for system info? Anyone know how I can debug this?
Thanks!
-Jason
    Problem solved... Simply change eth1 device to eth0. Seems like Quartus assumes you always have a device no eth0.
    From SuSE 11.3 terminal as root user:
    #  rcnetwork stop#  vim /etc/udev/rules.d/70-persistent-net.rules
    Changed the device name to "eth0" in this file. Reboot and done!
    Hope this helps others...
    -J
    Altera's aware of that bug (I reported it some time ago) and AFAIK it only affects those using Linux/UNIX systems.
    --slacker
