14 years ago
Linux install 10.1 on Jolicloud or Ubuntu netbook remix
It works, but you must do the dash to bash hack on the alterawiki under installing 9.1 on ubuntu linux. As soon as the install is done you may rehack back to using dash as the default shell. Not sure if device programming works yet as I have the old byte blaster II and not the usb blaster.
The X7 at http://nibz.googlecode.com was compiled for the 1270 MAX II with no VHDL errors. @75% @85MHz.
I hope a simple dash change and install script can become available, with the change back to dash after the install.
