AlexBeasley's avatar
AlexBeasley
4 years ago
Linking fftw3 lib into SystemVerilog Simulation with DPI-C
Hi there,
I am trying to run a simulation that makes use of the DPI-C interface so I can compare the FPGA output with the same function being performed in C.
For this I need to compile in the FFTW3 libraries for my C code.
Below are some examples of the code and compilation set up
C Code includes
#include "./fftw3.h"
#include "svdpi.h"
#include "svdpi_src.h"
SV code imports
import "DPI-C" task fft2d();
Compilation and vsim set up
vlog -dpiheader dpi_header.h C:/Data/fpga/DPI_C/fourier_fftw.c
# compile toucan testbench
vlog -reportprogress 300 -work work +acc C:/Data/fpga/Testbenches/Toucan_tb.sv
# # Set the top-level simulation or testbench module/entity name, which is
# # used by the elab command to elaborate the top level.
set TOP_LEVEL_NAME Toucan_tb
# # Set any elaboration options you require.
set USER_DEFINED_ELAB_OPTIONS {-c -ldflags "-llibfftw3-3" -ldflags  "-llibfftw3f-3" -ldflags "-llibfftw3l-3" -64}
# # Call command to elaborate your design and testbench.
elab
However, every time I try to run the simulation I get the following fatal error:
# ** Fatal: (vsim-3828) Could not link 'vsim_auto_compile.dll': cmd = 'C:/intelFPGA_pro/21.3/questa_fse\gcc-7.4.0-mingw64vc15\bin\gcc.exe -shared -o "C:/Users/ALEXBE~1/AppData/Local/Temp\AlexBeasley@ALEXVIVIDQLAPTO_dpi_34940\win64_gcc-7.4.0\vsim_auto_compile.dll" C:/Data/fpga/Sim/Toucan/libraries/work\_dpi\auto_compile@\win64_gcc-7.4.0\fourier_fftw.o   -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3 -Wl,-Bsymbolic  -L"C:/intelFPGA_pro/21.3/questa_fse/win64" -lmtipli'
# (vsim-50) A call to system(C:/intelFPGA_pro/21.3/questa_fse\gcc-7.4.0-mingw64vc15\bin\gcc.exe -shared -o "C:/Users/ALEXBE~1/AppData/Local/Temp\AlexBeasley@ALEXVIVIDQLAPTO_dpi_34940\win64_gcc-7.4.0\vsim_auto_compile.dll" C:/Data/fpga/Sim/Toucan/libraries/work\_dpi\auto_compile@\win64_gcc-7.4.0\fourier_fftw.o   -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3 -Wl,-Bsymbolic  -L"C:/intelFPGA_pro/21.3/questa_fse/win64" -lmtipli) returned error code '1'.
# No such file or directory. (errno = ENOENT)
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./compile_toucan.do PAUSED at line 99
I cannot work out where I am going wrong or what file is being referred to by the "No such file or directory. (errno = ENOENT)" line.
The fftw3 files were downloaded directly from the FFTW website as a set of pre-compiled dlls for windows. The lib files were then generated using the lib.exe function within Visual Studio.
Any ideas?
  • Hi there,
    I worked it out; because the .lib files were in a directory that was not being searched automatically I had to add -L<lib_directory> into the -ldflags command. i.e.:
    vsim -c -ldflags "-L./ -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3" -64 work.fftw3_tb
    This now works.
    Cheers
    Alex
  • ShengN_altera's avatar
    ShengN_altera
    You need to pass your library to 64 bit. For example like this:
    vsim -c -ldflags "-l<library>" -64
    Sheng
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
  • AlexBeasley's avatar
    AlexBeasley
    Hi there,
    Thanks for getting back to me.
    I have tried passing in the -64 flag with the -ldflags command using the following commands:
    vlog -dpiheader myheader.h fourier_fftw.c fftw3_tb.sv
    vsim -c -ldflags "-llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3" -64 work.fftw3_tb
    But I still get the following error in the output:
    # vsim -c -ldflags "-llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3" -64 work.fftw3_tb
    # Start time: 09:00:33 on Jul 20,2022
    # ** Note: (vsim-3812) Design is being optimized...
    # Loading sv_std.std
    # Loading work.fftw3_tb(fast)
    # ** Fatal: (vsim-3828) Could not link 'vsim_auto_compile.dll': cmd = 'C:/intelFPGA_pro/21.3/questa_fse\gcc-7.4.0-mingw64vc15\bin\gcc.exe -shared -o "C:/Users/ALEXBE~1/AppData/Local/Temp\AlexBeasley@ALEXVIVIDQLAPTO_dpi_23316\win64_gcc-7.4.0\vsim_auto_compile.dll" c:/Data/fpga/sim/fftw3_example/work\_dpi\auto_compile@\win64_gcc-7.4.0\fourier_fftw.o   -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3 -Wl,-Bsymbolic  -L"C:/intelFPGA_pro/21.3/questa_fse/win64" -lmtipli'
    # (vsim-50) A call to system(C:/intelFPGA_pro/21.3/questa_fse\gcc-7.4.0-mingw64vc15\bin\gcc.exe -shared -o "C:/Users/ALEXBE~1/AppData/Local/Temp\AlexBeasley@ALEXVIVIDQLAPTO_dpi_23316\win64_gcc-7.4.0\vsim_auto_compile.dll" c:/Data/fpga/sim/fftw3_example/work\_dpi\auto_compile@\win64_gcc-7.4.0\fourier_fftw.o   -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3 -Wl,-Bsymbolic  -L"C:/intelFPGA_pro/21.3/questa_fse/win64" -lmtipli) returned error code '1'.
    I don't know if it is looking for the libfftw3 libraries in a certain location? Currently they are in the working directory of QuestaSim.
    I have attached the example I am using to try and get this working. There is a "compile.do" file which has my commands in to compile the source files and run the simulation.
    Any ideas?
    Alex
    ShengN_altera
    I think not need to flag those libraries. Questa can run the simulation without flagging those libraries.
    ShengN_altera
    Any further update or concern? Do you able to run the simulation?
    AlexBeasley
    Hi there,
    This now works.
    Cheers
    Alex
    ShengN_altera
    Thanks for the sharing.
    Btw, I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
