AlexBeasley's avatar
AlexBeasley
4 years ago
Linking fftw3 lib into SystemVerilog Simulation with DPI-C
Hi there, I am trying to run a simulation that makes use of the DPI-C interface so I can compare the FPGA output with the same function being performed in C. For this I need to compile in the...
  • AlexBeasley's avatar
    4 years ago
    Hi there,
    I worked it out; because the .lib files were in a directory that was not being searched automatically I had to add -L<lib_directory> into the -ldflags command. i.e.:
    vsim -c -ldflags "-L./ -llibfftw3-3 -llibfftw3f-3 -llibfftw3l-3" -64 work.fftw3_tb
    This now works.
    Cheers
    Alex
