Limit to one attempt fitter option gone?
There was in the past an option to limit the Quartus fitter to one attempt,
which made the first effort bigger and skip the expected fitting effort to fail:
I cannot find this option anymore in Quartus prime standard edition.
I'm asking because my fitting only succeed on the second attempt:
Info (170134): Cannot fit design in device -- retrying with increased optimization that can result in longer processing time
Info (170138): Failed to route the following 9 signal(s)
Info (170140): Cannot fit design in device -- following 12 routing resource(s) needed by more than one signal during the last fitting attempt
Info (170194): Fitter routing operations ending: elapsed time is 01:07:17
Warning (170136): Design uses Placement Effort Multiplier = 4.0. Using a Placement Effort Multiplier > 1.0 can increase processing time, especially when used during a second or third fitting attempt.
Maybe that the option has been renamed?
Kind Regards,
Alex.
- AEsqu
Contributor
I use version 21.1.1
- sstrell
It may have been removed at some point or maybe your device doesn't support it. You could try adding it to the .qsf:
https://www.intel.com/content/www/us/en/docs/programmable/683084/current/fit-attempts-to-skip.html
https://www.intel.com/content/www/us/en/docs/programmable/683084/current/fit-only-one-attempt.html
- AEsqu
Contributor
Thank You,
I will try and see how it goes with the Cyclone V (I don't see it in the list)
set_global_assignment -name FIT_ATTEMPTS_TO_SKIP 1
or
set_global_assignment -name FIT_ATTEMPTS_TO_SKIP 2
- AEsqu
Contributor
This is not working, when I add that in the .qsf, Quartus tells me there is an error in it and removes that line.
Also, in the assignment editor GUI, that option is not present.
- AEsqu
Contributor
Can the option be added in future version of Quartus for the cyclone V?
