License issue for simulation in Quartus
- 4 years ago
I got my license on this link: Intel® FPGA self-service licensing center
Thank you Larry and Prabhakar.
Hi
Welcome to Intel forum. For your information, we are working remotely from Penang, Malaysia and generally do not provide phone call/zoom meeting or any remote access link support in forum. However, if you have any question regarding licensing that need some explanation. Kindly list down your question in this forum and I will try my best to help you.
For fast support in your local geo, please kindly contact your nearest Intel distributor. You could refer the contact for our sales and distributor from link below:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Appreciate much on your understanding.
Hey
Thank you for replying.
So my issue is that I am not able to simulate.
- Upon running compilation the following errors pop up.
Error: Error: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: Error: NativeLink simulation flow was NOT successful
Error (23031): Evaluation of Tcl script e:/intelfpga_lite/21.1/quartus/common/tcl/internal/nativelink/qnativesim.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 633 megabytes
Error: Processing ended: Fri Nov 26 11:08:05 2021
Error: Elapsed time: 00:00:06
Error: Total CPU time (on all processors): 00:00:02
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 13 warnings
- Upon running the functional simulation in university program VWF, the following error is being displayed:
**** Running the ModelSim simulation ****
E:/intelFPGA_lite/21.1/questa_fse/win64/vsim -c -do counter.do
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Error.
- Upon running lmutil lmdiag the following message is popping up:
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Fri 11/26/2021 11:22
License file: C:\Program Files\Maple 2021\license\license.dat
"Maple" v2022.0630, vendor: maplelmg, expiry: 08-nov-2021
uncounted nodelocked license, locked to ethernet address "a81e848a72de",
or ethernet address "1a4a8155abb5",
or Disk serial number "DISK_SERIAL_NUM=90cff0da" starts: 1-jan-1990, expires: 08-nov-2021
TS_OK: Checkout permitted when client is using terminal client
This license cannot be checked out because:
Feature has expired.
Feature: Maple
Expire date: 08-nov-2021
License path: C:\Program Files\Maple 2021\license\license.dat;E:\intelFPGA_lite\21.1\questa_fse\win64\*.lic;
FlexNet Licensing error:-10,32
- I figured there is some problem with the license and therefore tried to access the license self help center and got redirected to chat for associate partners of intel. Somebody called Twinkle in the chat raised a ticket for me regarding this and instructed me to follow up my query on this forum. So here I am.
Kindly help me solve this issue. I am attaching screenshots of the above mentioned errors for you reference.
