11 years agolibrary use clause errors
I am using Altera version 13.0.0. The compiler is complaining about this code: library ieee; use ieee.std_logic_1164.all; library basicblocks; use basicblocks.d_flipflop.all...
11 years ago@tricky:
I am still getting use clause errors. The error below appears if I have a files named basicblocks.vhdl, basicblocks.vhd, d_flipflop.vhdl, and d_flipflop.vhd. All of these files contain a valid entity and architecture of name "d_flipflop". I get the same result if the library directory is empty. Error (10481): VHDL Use Clause error at tps2834.vhdl(34): design library "basicblocks" does not contain primary unit "d_flipflop" Lines 34-41 of tps2834 are u2: entity basicblocks.d_flipflop port map( clock => not pwm, preset => '1', clear => enable, d => continuous, q => continuous_sample, qbar => open ); Does the definition of "primary unit" exclude entities and architectures? If so, what is an acceptable design unit? I am aware of the nearly equivalent library design unit dff; I am pursuing this to clear up my understanding of how to create my own libraries. @Rysc: This works. It seems that the altera libraries are treated as standard vhdl libraries, but user libraries are not. Cheers John
