ksubi
7 years agoleft bound (21) fo slice must belong to range & formal port or parameter must have actual or default value
I have two errors. "left bound (21) of slice must belong to range (18 downto 0) of corresponding object" and "formal port of parameter "x_i" must have actual or default value". How can I fix it? H...
mfro
7 years agoYou are exceeding the allowed range for x_i. It is defined as
Signal eX: std_logic_vector (18 downto 0);, but later on, you attempt to iterate across it like this:
iter: for i in 0 to 7 generate
mult : booth_unit
port map
P => wires(i),
Y => b,
x_i => eX(3*i+3 downto 3*i),
Z => p(3*i+2 downto 3*i),
P_n => wires(i+1)
); -- booth_unit
end generate;Note: you are iterating i from 0 to 7, but 3 * 6 + 3 is already exceeding the bounds of the vector. No idea what you are trying to do, but the loop should probably go from 0 to 5 only...
The second error is most likely only a consequence of the first.
