14 years agoled_driver
Can anyone help me determine that I have translated it all correct please?
original verilog:module led_driver (iRSTN, iCLK, iDIG, iG_INT2, oLED);
input iRSTN;
input iCLK;
input iDIG;
input iG_INT2;
output oLED;
// REG/WIRE declarations
wire select_data;
wire signed_bit;
wire abs_select_high;
reg int2_d;
reg int2_count;
reg int2_count_en;
// Structural coding
assign select_data = iG_INT2 ? iDIG : // +-2g resolution : 10-bit
(iDIG?(iDIG?iDIG:5'h10):(iDIG?5'hf:iDIG)); // +-g resolution : 9-bit
assign signed_bit = select_data;
assign abs_select_high = signed_bit ? ~select_data : select_data; // the negitive number here is the 2's complement - 1
assign oLED = int2_count ? ((abs_select_high == 3'h0) ? 8'h18 :
(abs_select_high == 3'h1) ? (signed_bit?8'h8:8'h10) :
(abs_select_high == 3'h2) ? (signed_bit?8'hc:8'h30) :
(abs_select_high == 3'h3) ? (signed_bit?8'h4:8'h20) :
(abs_select_high == 3'h4) ? (signed_bit?8'h6:8'h60) :
(abs_select_high == 3'h5) ? (signed_bit?8'h2:8'h40) :
(abs_select_high == 3'h6) ? (signed_bit?8'h3:8'hc0) :
(signed_bit?8'h1:8'h80)):
(int2_count ? 8'h0 : 8'hff); // Activity
always@(posedge iCLK or negedge iRSTN)
if (!iRSTN)
begin
int2_count_en <= 1'b0;
int2_count <= 24'h800000;
end
else
begin
int2_d <= {int2_d, iG_INT2};
if (!int2_d && int2_d)
begin
int2_count_en <= 1'b1;
int2_count <= 24'h0;
end
else if (int2_count)
else
int2_count <= int2_count + 1;
end
endmodule
my vhdl:
-- led_driver.vhd
-- [email protected] 16 Feb 2012
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity led_driver is
-- Port -----------------------------------------------------------------------
-- Comes from other files or from the card
port (
iCLK : in STD_LOGIC; -- CLOCK_50
iG_INT2 : in STD_LOGIC; -- G_SENSOR_INT
iRSTN : in STD_LOGIC; -- NOT RESET
iDIG : in STD_LOGIC_VECTOR(7 downto 0); -- CONTROL SIGNAL
oLED : out STD_LOGIC_VECTOR(7 downto 0) -- OUT LEDS
end;
architecture struct of led_driver is
-- SIGNALS
SIGNAL select_data : STD_LOGIC_VECTOR(4 downto 0);
SIGNAL signed_bit : STD_LOGIC;
SIGNAL abs_select_high : STD_LOGIC_VECTOR(3 downto 0);
SIGNAL int2_d : STD_LOGIC_VECTOR(1 downto 0);
SIGNAL int2_count : STD_LOGIC_VECTOR(23 downto 0);
SIGNAL int2_count_en : STD_LOGIC;
-- START
begin
-- Output logic
--oLed <= signalsoLed;
oLED(2) <= '1';
-- Should we reset?
process(iCLK, iRSTN) begin
IF ((NOT(iRSTN)) = '1') THEN
int2_count_en <= '0';
int2_count <= "100000000000000000000000";
ELSIF (iCLK'EVENT AND iCLK = '1') THEN
int2_d <= (int2_d(0) & iG_INT2);
IF (NOT(int2_d(1)) AND int2_d(0)) THEN
int2_count_en <= '1';
int2_count <= "000000000000000000000000";
ELSIF ((int2_count(23)) = '1') THEN
ELSE
int2_count <= int2_count + "000000000000000000000001";
END IF;
END IF;
end process;
end struct;
