CFabr1
3 years agoLED circuit issue with CPLD and Quartus
Hi all,
I'm trying to implementing under Quartus this simple LED circuit (based on two D flip-flops) using a +5V CPLD (EPM7032)
As you can see, there are only three signals inputs to the ...
sstrell
3 years agoThese are positive edge-triggered flip-flops so the fact that the "clocks" are normally held high is not going to give you accurate behavior. Perhaps you should be using the /Q outputs instead.
