CFabr1
3 years agoLED circuit issue with CPLD and Quartus
Hi all,
I'm trying to implementing under Quartus this simple LED circuit (based on two D flip-flops) using a +5V CPLD (EPM7032)
As you can see, there are only three signals inputs to the ...
ShengN_altera
3 years agoHi,
Tested with no problem as well.
Check the image and folder attached.
Sheng
- CFabr13 years ago
I see.
Anyway, OPT01 and OPT13 are active LOW signal so, normally they are fixed HIGH and then get asserted to LOW for 2.5us.As well as, LED_CATHODE1 and LED_CATHODE2 shoud be fixed HIGH so that the LEDs will not blink because both anodes are wired to +5V thru 220 Ohm resistors.Therefore, the LEDs should blink only when LED_CATHODE1 and LED_CATHODE2 toggle to LOW.
