CFabr1
3 years agoLED circuit issue with CPLD and Quartus
Hi all,
I'm trying to implementing under Quartus this simple LED circuit (based on two D flip-flops) using a +5V CPLD (EPM7032)
As you can see, there are only three signals inputs to the ...
ShengN_altera
3 years agoHi,
The functionality of the Megafunction tested with no problem check the image attached.
While OPT02 is asserted, LED1_CATHODE will toggle. As OPT13 is not asserted, LED2_CATHODE will not toggle.
Sheng
CFabr1
3 years agoThanks for reply.The problem is that, when the only OPT13 is asserted both LEDs toggle while only LED2_CATHODE should actually toggle.
P.S.
OPT02 and OPT13 are coming from an old japanese computer.
