11 years agoLCD Procedure code
I need a procedure to write a word in the lcd that I can call any time, so i thought of something like this:
procedure write1 is variable cont1: integer range 0 to 18; begin for cont1 in 0 to 18 loop case cont1 is when 0 =>lcd_rs<='0'; lcd_data<=x"C0"; when 1 =>lcd_e<='1'; when 2 =>lcd_e<='0'; when 3 =>lcd_rs<='1'; when 4 =>lcd_data<=x"4C"; --L when 5 =>lcd_e<='1'; when 6 =>lcd_e<='0'; when 7 =>lcd_data <=x"49"; --I when 8 =>lcd_e<='1'; when 9 =>lcd_e<='0'; when 10 =>lcd_data <=x"4B"; --K when 11 =>lcd_e<='1'; when 12 =>lcd_e<='0'; when 13 =>lcd_data <=x"45"; --E when 14 =>lcd_e<='1'; when 15 =>lcd_e<='0'; when 16 =>lcd_rs<='0'; lcd_data<=x"80"; when 17 =>lcd_e<='1'; when 18 =>lcd_e<='0'; lcd_rs<='1'; end case; end loop; end write1; I want to use it like this in a fsm: if(w1='1' and w2= '0' and w3 = '0') then write1; elsif(w1='0' and w2 = '1' and w3 = '0') then write2; elsif(w1='0' and w2 = '0' and w3 = '1') then write3; elsif(w1 = '0' and w2 = '0' and w3 = '0') then clearline2; end if; But it seems i got all wrong, can someone explain what i should do?
