9 years agolatency in 1 port ram help
Hello, I am new to vhdl. I am using the on chip RAM and the built in integer comparator to do something as following: 1. memory_a & memory_b both are the on chip ram with size 32 bit * 128...
9 years agoHi,
yes, there will always be a delay. However, all you have to do is to "disable" the comparator during the time that the data is invalid. That's no particular VHDL trick, it's just a thing you have to get use to when doing hardware (it gets worse with SDRAM chips, where the timing can differ when you hit a refresh cycle...). Here's some example code:library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity example is
port(
clk, rst: in std_logic;
test_request: in std_logic;
test_address: in std_logic_vector(6 downto 0);
test_pass: out std_logic;
test_fail: out std_logic);
end entity;
architecture rtl of example is
component my_memory is
port(
address: in std_logic_vector (6 downto 0);
clock: in std_logic;
data: in std_logic_vector (31 downto 0);
wren: in std_logic;
q: out std_logic_vector (31 downto 0));
end component;
signal data_a, data_b: std_logic_vector (31 downto 0);
signal delay1, delay2: std_logic;
begin
my_memory_inst_a: my_memory
port map(
address => test_address,
clock => clk,
data => (others => '-'),
wren => '0', -- never write (memory is pre-initialized)
q => data_a);
my_memory_inst_b: my_memory
port map(
clock => clk,
q => data_b);
process(rst, clk) is
begin
if(rst = '1') then
delay1 <= '0';
delay2 <= '0';
elsif(rising_edge(clk)) then
-- delay request signal
delay1 <= test_request;
delay2 <= delay1;
end if;
end process;
begin
if(rst = '1') then
test_pass <= '0';
test_fail <= '0';
-- default assignments
test_pass <= '0';
test_fail <= '0';
-- compare data
if(delay2 = '1') then -- note that delay2 is in sync with the read data
if(data_a = data_b) then
test_pass <= '1';
else
test_fail <= '1';
end if;
end if;
end if;
end process;
end architecture; The idea is that you assert the address ("test_address") you want to compare, while in the same clock cycle setting "test_request" to '1'. By delaying the request signal by two clocks, "delay2" will be '1' exactly two cycles after the data was requested, which is the exact same clock cycle when the data is returned from the RAM (in your case, you said it's two clocks). That's just some example code to give you the idea. I didn't compile it, but it should work, maybe there are a few syntax errors. Best regards, GooGooCluster
