11 years agoLatching data to same register from 2 independent processes
I need to write to a register from 2 sources.. a pci host and a microcontroller. The 2 will never access the register at the same time (basically once the PCI is done , it hands it over the other host, which will then have exclusive access until it's finished).
Since the clock domains are different, I can't just have multiple processes writing to the same register or the synthesizer will complain...
always @(posedge pciclk or negedge nrst)
if pci_wr & pci_addr == 0
cntl_reg = pci_data
always @(posedge mcclk or negedge nrst)
if mc_wr & mc_addr == 0
cntl_reg = mc_data
On the other hand, how can I insert a mux such that pci data is latched based on the pci clock / wr strobe, as well as micro data latched on the microcontroller's clock/wr strobe. So how this is typcally done? Not sure if this a fundamental architectural question, or just a syntax question on how to write the sensitivity list. Thanks!
