9 years agoLatches in frequecny divider using fsm implementation
I am new to verilog and HDL. I want to implement a N-frequency divider, which count clock ticks (pos and neg) and start the counting mechanism from the first rising edge of the input clk. In a...
9 years agoFPGAs do not support dual edge flip flops. Plus Synthesis tools (but not simulators) ignore the sensitivity list of the always block. Hence, if you write:
always @(clk) The synthesis tool ignores it, and treats it as always @(*) This is because synth tools have to infer logic from your code, and have to follow specific templates to generate specific logic. See https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf , section 2-12 for recommended HDL coding styles. The problem with writing always @(clk) Is that in simulation it will behave like a dual edge flop, but as synthesis treats it as always @(*), the simulation behaviour and real hardware behaviour will not match. This is why you get warnings about latch generation when you may have a perfectly good simultion.
