9 years agoLatches in frequecny divider using fsm implementation
I am new to verilog and HDL. I want to implement a N-frequency divider, which count clock ticks (pos and neg) and start the counting mechanism from the first rising edge of the input clk. In a...
9 years agoHi Tricky,
writing always@(clk) means it will execute the process for each changing in clk signal, in other words sesitivity for both rising or falling edges. However as you said FPGAs doesn't support dual edge flip flops. What am I missing? Sorry, I really don't get it when dual edge sensing is valid and when it's not. And why I don't get any synthesis errors if the HDL code is not suitable for the target device?
