9 years agoLatches in frequecny divider using fsm implementation
I am new to verilog and HDL. I want to implement a N-frequency divider, which count clock ticks (pos and neg) and start the counting mechanism from the first rising edge of the input clk. In a...
9 years ago --- Quote Start --- Hi Tricky, Thank you for your reply. If I get it right, always @(clk) begin ... end or always @(*) are supported for compilation only but not for simulation and programming into FPGAs. Am I correct? Thanks --- Quote End --- Incorrect. They are a legitimate way of coding verilog, for creating logic or latches, which are both suitable for FPGAs.
