Latch clocked by "rst" signal
There must be an error in your HDL code that is making the compiler think this is a clock signal. Can you post the code?
- sstrell6 years ago
I think the problem is poor code or an error in the code. From what you posted:
process(sda_clk, start_async_rst)
begin
if (start_async_rst = '1') then
sda_f <= sda_in;
elsif (rising_edge(sda_clk)) then
sda_f <= sda_in;
end if;
end process;sda_f is getting inferred as a latch instead of a register because the reset is coded incorrectly. sda_f should get 0, I would presume, when start_async_rst equals 1. As such, start_async_rst (and its source, rst) are inferred as a clock gate essentially, so Quartus thinks it needs a clock assignment. So I don't know if that is an error in the IP you got, but a coding issue is causing the warning.
- aroturier6 years ago
Ok, i see what is the problem.
I don't need an asynchronous reset, so i just rewrite it like this, and it works well :
process(sda_clk)
begin
sda_f <= sda_in;
end if;
end process;Thank you for your help,
Antoine
