16 years ago
Keyboard num lock scan code problem.
Hi, Ive got a problem with implement the scan codes for the case which num lock is on. i would like to use keypad 1-9 number on the keyboard as numbers, not as arrows, pg dn, pg up, etc.. the scan codes shown in easy scan.bmp shown below, i can easily implement. for example using the following process below because the scan codes are 8 bits long as shown here (example) https://www.alteraforum.com/forum/attachment.php?attachmentid=2161
PROCESS (scan_code, ready_set)
BEGIN
IF (ready_set = '1') THEN
CASE scan_code IS
WHEN "00011100" => -- A
temp1 <="00011100";
data1 <= "1111001";
data0 <= "1000000";
WHEN "00110010" => -- B
temp1 <="00110010";
data1 <= "0100100";
data0 <= "1000000";
WHEN "00100001" => -- C
temp1 <="00100001";
data1 <= "0110000";
data0 <= "1000000";
WHEN "11110000" => -- break code
if temp1 ="00011100" then --A
data1 <= "1111001";
data0 <= "1000000";
ELSIF temp1 ="00110010" then --B
data1 <= "0100100";
data0 <= "1000000";
ELSIF temp1 ="00100001" then --C
data1 <= "0110000";
data0 <= "1000000";
ELSE
NULL;
END IF;
WHEN OTHERS => null;
END CASE;
END PROCESS;
but the problem arises when i have to use the keypad numbers. the make and break codes for the keys are longer than 8 bits as shown here https://www.alteraforum.com/forum/attachment.php?attachmentid=2162
the reason why i want to use them as numbers, keypad 1(End), 2(Down), 3(Page Down), 4(Left), 6(Right), 7(Home), 8(Up), 9(Page Up) keys and keyboard's Home, Page up, Page down, End, Up, Down, Left & Right, share same scan codes when num lock is off. i really dont how to go about solving this problem (to write the process required). The complete keyboard code is attached. please help me out guys.
Dante
