8 years ago[Kernel vectorization] Loads/Stores cannot be vectorized
Hi guys! The compiler says this on the above code: Compiler Warning: Vectorized kernel contains loads/stores that cannot be vectorized. This might reduce performance. What loads/st...
8 years ago --- Quote Start --- The likely case is the following part:
if(local_id == 0)
group_counters = local_counter; SIMD vectorizes operations at work-item level, and coalesces accesses that are consecutive at this level. For this particular access, since the write is done only by one work-item per work-group, it cannot be vectorized/coalesced. --- Quote End --- Always right mate :) Thanks HRZ
